I have searched here & pirate 4x4 threads and found some info on this fix but no good pics. Has anyone done this fix? It looks like using a big U bolt puts it at an angle which I don't like. A straight path would have it running right up ontop of the dif cover bolt heads. Over on pirate one guy made a plate mounted to the bottom of the axle and used Square U bolts pointing up, nice method but loses ground clearence by just a bit. Anyone have a method you have used that works? If not I will think of something. Thanks.
