I removed the 10 bolt last night and am getting ready to install the D60. My own research and CK5 member comments indicate that the front u-joint should be a direct fit. I pulled one of the u-joint caps and put it in the D60 yoke and it (the cap) is too small.
Is there a different u-joint I can buy that has two smaller caps to fit the d-shaft and larger caps to fit the D60 yoke?
