I used the Superlift u bolt kit to install my D60 in my Jimmy today. The issue are the 2 studs. There is not enough threads for the nuts to contact the spring plate. Can I use washers for spacers ? Or can I reuse the stock bolts , they fit. Also there is a gap between the spring plate and axle on the stud side. Is this a problem or not? Thanks.
