Can anyone describe how easy it should be to turn the hub when the wheel bearings have the right preload? I torqued it down pretty tight to try and make sure everything was seated, then was trying to back off until the hub rotation felt right. Torque on the nut was sort of all or nothing... I picked a spot that seemed about right, but now I'm second guessing. The hub is slightly hard to turn just by hand using the wheel studs as a handle, certainly quite far from just spinning freely. I'm thinking it might be better to err on the side of too much preload vs. having any significant slop, but I'm not sure. Any advice how to get this right?
