Yup, as said, pretty rare on K30. Fairly common on 1/2 and 3/4T. I've run the 10 bolt version with good luck even on the trail but I did understand how they work and had a pretty specific driver to put them back in. I lived within a few highway miles of my parents and inlaws 10-ish miles to town and all our driveways often required 4wd in the winter and I didn't like leaving hubs locked all the time on the highway and also go tired of getting out to lock hubs all the time. Do the auto hubs were great.
The synchro 205s are fine and there were a LOT of them built. I'm sure it was far more than the number of trucks that actually got auto hubs. It's not just he clutch ring that's different, it's every single part of the front output assembly. So if you want to go to a 32 spline, you really need the entire assembly from another 205 to do it. The good news is that the assembly is pretty strong so unless you're pushing the limits of the 30 spline shaft (which not many people actually do) it's generally a solid system.
