D70HD Detroit Locker Preload?
Gunny65
Oregon
I am putting in a new Detroit locker with new 4.88 ring and pinion in my D70HD axle. The old carrier is a one peice with 4.10 gears. Since this is all new stuff, how would I determine preload?
If I understand it, I must put the shims in place before I set the race and bearings. If I am wrong, isn't it a bit hard on the race and bearings to pull off then back on then off again, etc?
I can't answer the preload question but you are correct about the shim installation. They are between the carrier and bearing so they have to be pressed on and off a few times to set it up. If you've got a good/correct puller it can be down without damaging the bearings.
Thanks. I will read it also.
I found this Model 70 Maintenance Manual on the Dana site: http://www2.dana.com/pdf/5312-9.PDF
I was hoping to find an easier way to do this but it probably is best to stick with what is sure to work...if done correctly. The manual also provides a worksheet to help set up preloads. Not bad really.
Pirate says the pinion nut is a 15/16 thin wall socket. The other manual said a 1-15/16" thin wall socket. Then another, Randy's ring and pinion says the nut is 1-5/16". Anyone know which it actually is?
1&5/16"
You set the preload with shims under the bearing toward the spline, its a slip fit bearing
1-5/16", that is what I figured. It looked closer to 1-1/4" than 2" and and 1" was just a tad too small. Thanks for the help.
