Dad's 1978 Chevy K30 Farm Truck
Dad's K30
I found damage to the back of the cab I missed before. Looks like something hit the front of the bed hard, then went through the factory slider window. It has also been resprayed, at least partially at some point.
RPO decoding:
AK9 RESTRAINT SYSTEM, RR SEAT, SHLDR, RETR, 3 POINT
AS3 SEAT,#2 REAR UTILITY
AU3 LOCK,SIDE DOOR,ELECTRIC
A01 WINDOW,TINTED GLASS(ALL WINDOWS)
A28 WINDOW,SLIDING GLASS,REAR WINDOW
A31 WINDOW,POWER OPERATED,ALL DOORS
A52 SEAT,FRONT BENCH,3-PASSENGER
BB5 ORNAMENTATION,INTERIOR,HEADLINER
BC3 ORNAMENTATION, INTR, I/P, DELUXE
BS4 INSULATION,BACK PANEL
BY1 ORNAMENTATION, EXTR EMBLEM, BODY, VAR 3
B30 COVERING, FLOOR CARPET
B93 ORNAMENTATION, EXTR MLDG, DR EDGE GUARD
CD4 WIPER SYSTEM,WINDSHIELD,PULSE
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS
C7A GVW RATING(10000 LBS)
C91 LAMP,INTERIOR,ROOF COURTESY(DOME)
D1V GEAR SPEEDO DRIVEN (1359272)
D34 MIRROR,INSIDE,SUNSHADE
D45 MIRROR,OUTSIDE,BELOW EYELINE(STAINLESS STEEL)
E4J EQUIPMENT CKD POLAND
E6D COUNTRY GAZA
E63 BODY EQUIPMENT,FLEETSIDE PICKUP BOX
E8A COVER,RR COMPT TONNEAU - DELETE
F58 BAR,HEAVY DUTY FRONT STABILIZER
F61 SHAFT,REAR STABILIZER
GT5 AXLE,REAR,4.10 RATIO
G60 SPRING,REAR AUXILIARY
JAN PLANT CODE - JANESVILLE, WI, BOC
JB8 BRAKE SYSTEM,HYDRAULIC POWER DISC,DRUM
KC4 COOLING SYSTEM,ENGINE OIL
K19 REACTOR SYSTEM,AIR INJECTION
K22 GENERATOR,94 AMPERE
K34 CRUISE CONTROL, AUT0MATIC, ELECTRONIC
L19 ENGINE, GAS, 8 CYL, 7.4L, 1TBI, VB
MX1 TRANSMISSION,AUTOMATIC(MERCHANDISING OPTION)
M40 TRANSMISSION,AUTOMATIC 3-SPEED(THM400-475/3L80)TRANSMISSION,3-SPD AUTOMATIC
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS
NL2 FUEL TANK,AUXILIARY
N31 STEERING WHEEL(CUSTOM)
N33 STEERING COLUMN,TILT
PA1 COVER,WHEEL TRIM(DELUXE)
P11 CARRIER,GLIDE OUT SPARE TIRE
R05 WHEELS,DUAL REAR
SLM SALES PROCESSING STOCK ORDERS
TP2 BATTERY,AUXILIARY CAMPER
TR9 LAMP GROUP,COURTESY
TT4 HEADLAMPS HALOGEN, 4
T63 WARNING SYSTEM,HEADLAMPS ON ALARM
UA1 BATTERY,HEAVY DUTY
UF2 LAMP,CARGO
UN9 RADIO SUPPRESSION EQUIPMENT
UP8 RADIO,PROVISIONS FOR STEREO INSTRUMENTATION
UX1 RADIO,AM/FM STEREO,WEATHER,CASSETTE,EQUALIZER,ETR,INCLUDES CLOCK
UY1 WIRING HARNESS,CAMPER
U01 LAMP,FIVE ROOF MARKER,TRUCK
U37 LIGHTER,CIGARETTE
U73 ANTENNA,FIXED
V02 RADIATOR,HEAVY DUTY,INCLUDES HEAVY DUTY TRANSMISSION OIL COOLER
V22 GRILLE,RADIATOR(CHROME)
V31 GUARDS,FRONT BUMPER(CHROME)
V42 BUMPER,REAR STEP(CHROME)
V73 VEHICLE STATEMENT - US/CANADA
V76 HOOK,FRONT TOW
XYK TIRE FRONT LT215/85R-16D (STEEL BELTED) RADIAL HWY B/WALL
YD7 AXLE,FRONT(USED WITH R05)FOR SCHEDULING GVW PLATE
YE9 CONVENIENCE PKG COMFORT & DECOR LEVEL #3
YYK TIRE REAR LT215/85R16/D BL R/PE ST TL HWY (9590795)
ZN3 Not found
ZQ2 Power Convenience Package
ZYK TIRE SPARE LT215/85R16/D BL R/PE ST TL HWY (9590795)
ZY3 SPECIAL TWO-TONE
Z81 CAMPER EQUIPMENT
24D TRIM COMBINATION CLOTH, DK BLUE (D) (91)
24I INTERIOR TRIM,DARK BLUEINTERIOR TRIM,EBONY/BRICK
27A ACCENT STRIPE,LIGHT BLUE/DARK BLUEACCENT STRIPE,TWO TONE,DK SAPPHIRE/GARNET RED(92)
42U PRIMARY COLOR , EXTERIOR, SKY BLUE (91)
90L EXTERIOR COLOR,SECONDARY,GRAY METALLIC
Looks way better with it washed. So what's the plan? Cummins/Allison swap and keep it 2wd like you mentioned in another thread? Gonna keep the bed or go to a flatbed or service type bed?
Right now I'm looking into what I need for the Cummins swap. I will probably do that as a 2wd to start with. I'm also debating if I want to track down all the 89-91 grill parts or convert it over to the 73-80 front clip. I have all the parts for the early clip on hand. The contraption that donated 1 tons to @cheavyk10 M1009 has a good grill according to the guy parting it out as well. Unfortunately, it is hard to see in pics since it is covered with mud.
Fyi : allison can be changed from 2wd to 4wd or back with out full trans disassemble. Stand on bell housing and swap tail .
:popcorn:Will be following this as I have acquired a crew cab to do a 5.9, T5600 swap. Got a couple projects to move along before I dive into it.
Looks like TN Diesel aka @CrewCab59 is no longer around and his website is dead. So looking at motor mounts, I'm finding two that look identical. I'm not sure if summit is copying the other company or reselling the same parts.
Those are copying Scott’s design. Those unfortunately have the motor too far forward and don’t have enough room for the mechanical fan. It’s pretty universally agreed that electric fans don’t work well on the cummins. Rob bonney fabrication has the best fitting 2wd mounts available and I honestly think that might be the only ones.
Farmstrong just got into the game just a few weeks ago. See if you like his design.
So many people just slap diesel conversions together with electric fans and claim they cool correctly. Only way I ever see that possible is no towing or flat land use only. I'd do everything possible to get a mechanical fan setup in there if you want to actually work the truck.
The reviews on the cheap, summit brackets mentioned moving the stock mount back 1.5" to accommodate the mechanical fan.
I like the Ron Bonney 2wd mounts. They look stout. Although, it makes me question if I'm going to want to do the 4x4 swap first so I'm not redoing expensive parts again later. Or if I should just keep it 2wd.
This is the motor I'm using. 1996 6BT out of a motorhome with 35K miles.
For the transmission, I traded the Allison 4000 transmission for the Allison 1000 from a Chevy Duramax application. I then bought a second 1000 with an SAE bellhousing, wiring harness, and computer. Then found the smaller SAE Cummins adapter to match.
I believe I am going to be cutting out the transmission tunnel. I also have no idea what I'll need to make the shifter work, but it probably won't work with the factory column shift.
I might not be remembering correctly, was that engine out of a pusher motor home? Would/can you need to reverse the fan or did it 'pull' air?
