Dad's 1978 Chevy K30 Farm Truck
Dad's K30
That is a big part of the problem. the frame is nearly rusted in half in the middle and needs to be replaced. The cab is no longer held together with enough good sheetmetal to patch without replacing 60% of the sheetmetal in the process. The fenders, doors, and core support were all replaced previously and need to be replaced again. The bed that is on the truck is the third one since the truck was new and has serious rust in need of patch work.
I don't think I could do a real restoration on this truck in my lifetime and even if I did, 75% or more of the truck is getting replaced in the process. I've started this build about 6 different ways with 3 parallel paths in progress right now.
I also recently picked up a 1986 Chevy K30 cab chassis truck with a 454 big block and hydro clutch SM465. This gives me a good frame and cab to start this build if I go with a tribute build.
View attachment 530778View attachment 530779View attachment 530780View attachment 530781
Then, I have a very nice pair of doors from the RV cutaway parts truck with very nice West Coast mirrors. As well as the rust free but not perfect floor to use to patch a cab.
View attachment 530782View attachment 530783
I'm also stripping the 1978 C30 frame down to bare so I can paint it and start the build if I strip my dad's frame for the axles.
Imho, you gotta at least use something meaningful from the original truck, even if using a completely different cab. Like the dash. It's essentially just a few bolts and a series of spot welds at the base of the windshield.
Those houndstooth seats in the cutaway are awesome. I didn't realize those were available past '82... or at all in a pickup. Are they in good shape?
*edit* Thought it was an '85 for some reason. Maybe because the fender and door striping.
Gotta question: On your Dads ‘78 K-30 Cab Chassis gas tanks - is the impact barrier bracing a factory item ?
I’ve seen many Cab Chassis exposed tanks with those but not all inclusive through the years.
Are these aftermarket ?
I searched the GM Heritage History page for a RPO or option mentioned but they don’t really address Cab Chassis models in all areas.
