***Dads & Grads: 4.5” Resin Fiber Sanding Discs Starting at 35¢ Each***
Roark Supply
Registered Member
Orange, CA
In time for Father's Day and Graduation:
For those of you who prefer resin fiber sanding discs, we’ve found a new supplier. These discs are of higher quality and perform better than our previous (aluminum oxide and zirconia) resin fiber sanding discs. They are less expensive, to boot!
Aluminum Oxide Resin Fiber Sanding Discs and High Performance Zirconia Resin Sanding Fiber Discs
· Sold in boxes of 25
· Sizes: available in 4.5”, as well as 5”and 7”
· 16 grit to 120 grit
attachment.php
attachment.php
…and to entice you, we have a special introductory offer. Buy 4 boxes/get 1 box free. When you buy 4 boxes of the same size discs and material (zirconia or aluminum oxide), we’ll throw in a 5th box of like material discs for free. You choose the grit of the 5th box…if you don’t, we will.
By now, you know the drill…the special code in the Comments section qualifies you for the giveaway.
Special code = RESIN – CK5
This offer is good thru the end of June 2016.
***Roark Supply is a leading provider of abrasives used by fabricators, as well as off-road and custom car enthusiasts.
