So at what point do I condemn a throttle body assembly? Cause I'm about ready to.
1990 5.7 stock af.
I do understand that this is ancient technology but it should be running better than this imo. Current symptoms are that when its warming up on a cold start it will stumble and like misfire a little and then not happen again when warm. At all times now it seems it cant hold any steady rpm, but used to only be noticeable under coast or no load but trying to keep steady speed. Leaning on this being another TPS that only lasted a few months. Standard motor products brand.
If I'm gonna shotgun any more money into this I might as well get throttle shafts and FPR stuff with it.
There is this on ebay which has me interested. TBI assembly
I have personally replaced:
tune up: plugs wires cap rotor and ignition module.
throttle position sensor
coolant temp sensor
idle air control
manifold pressure
fuel filter
unknown miles on everything else.
1990 5.7 stock af.
coolant temp sensor
idle air control
manifold pressure
fuel filter
