I am having water pour out from my air tools and can't stand it anymore! So here to ask for help! It is 74 out side with 84% humidity the compressor is I/R SS5L5 Specifications:
Compressor is in a 6x8 garden shed with piping ran under ground then runs into shop vertical about 8 foot, there is leg about 5 foot up that splits and runs probably 30 foot around in garage with 2 outlets for air. Back to vertical part once reaches ceiling it runs probably 22 foot est then goes down 6 foot to last air out let. I have no water catches and water coming out so fast not sure they would help at this point plus air line is 3/4. I use standard 3/8 air hose for all 3 outlets but water is rushing out.
So what can I do to help????? I can move compressor in garage if needed is cooler in there. I hate to buy a dryer from I/R but if last resort would. Not sure can find water catchers that will work with 3/4 piping. Please help me out!!!!!
- Motor HP: 5 (5 hp running, 11.8 peak hp)
- Receiver tank size (gal): 60 Vertical
- Voltage: 230/1/60
- Capacity scfm @ 90 psig/135 psig: 18.1/15.5
- Maximum pressure psig: 135
- ACFM @ 40 PSI: 11.3
- Max PSI: 135
. Hoping the electrician will show tomorrow or weds at latest. So for now here are a few pics and will explain them for most part.
