Dana 44/10 bolt parts interchange
Treeman587
Registered Member
What parts will swap between a '84 10 bolt front axle and a '70's Dana 44 8 lug with a set of large spicer manual hubs? I am getting ready to do my swap and if I can keep the narrower 10 bolt width so I dont have to run wheel spacers on my 14 bolt I would like it much better. The dana 44 has the 4.10 gears I am going to run already installed.
Knuckles out are the same with the exception of some of the earlier D44's which used a small axle joint. Also there are 2 different spindles so swapping spindles out will take the guess work out of knowing if the rotor/hub assemblies will work with the spindles you have.
Thanks for the feedback. Now to see what combo I come up with between the two.
