Dana 44/12 bolt combo
noJeepshere
I Drove Trains!
Layton, UT
I'm afraid I have made the choice to part out the old beast, just can't justify having it around anymore:(
The front Dana 44 is in decent shape, straight, alignment is good, but needs hubs, as the WARN hub on there are toast. 3.73 gears.
Rear Corp 12-bolt, gov-bomb, 3.73 gears, new bearings and brakes. Good shape as well.
Both of these axles are good candidates for mild rebuilds to put under a mostly stock rig. PM if you would like more info or are interested in buying, preferably if you're around Eastern Washington.
I guess I should update my location, I live in Ephrata, at least that is where the old Jimmy is. PM sent.
