handloader90
Building!
Doing a 3/4 ton axle swap soon and need the bolt specs for a Dana 44 and 14BFF.
I will be using the Ruff Stuff diff covers on both axles, the diff covers are 3/8” thick.
I would prefer to use ARP for the bolts or studs.
Is it better to use a flat washer or lock washer for this application?
If anyone has part numbers for ARP bolt kits or stud kits for this application please share.
