Now I'm confused again. I can keep my existing calipers, but the brackets are different? I guess that makes sense since the rotors are likely in a different place in relation to the brackets?
I think I found some caliper brackets at the pick-n-pull today so I might be ok there. Also, while I was there, I found a C20 with a small full float axle in the rear. It looked like the size of a 10 bolt. Do you think that was factory?
I'm starting to add up all the costs and whew! The only reason I was considering this was because the rear axle tube has a big leak from the joint at the pumpkin. I think the tube has spun a bit and is also causing my back end to lean to one side.
So I thought "might as well..." switch to a full float axle while I'm at it to get better gears. Then I remembered I converted to rear disc brakes, so I'll need complete new rear brakes too.
Front hubs\rotors - $180
Front bearings, seals, pads etc. - $100
3.07 to 4.10 front gear swap - $300
Rear rotors - $120
Rear disc brackets - $60
rear calipers with ebrake - $300
14bff with 4.10 gears - $150
5 new 8-lug wheels - $360
$1480 + the stuff I always forget, all to fix my axle.
