Dana 44 and GM 14 Bolt - FREE in San Jose, CA
Tonyraca
Registered Member
San Jose, CA
The 14-bolt
I took it apart (except the differential) and was going to rebuild, but I bought a new truck instead. I've got all the parts to the original drum brakes taken off and removed the original spring mounts. All the pieces are there and just need someone to come and take them all away. I believe the gear ratio is 3.73. The yoke has a crack next to one of the bolt holes and could possibly be welded or just replaced all together.
The Dana-44
This axle is in the same condition as the 14 bolt, but I do have all of the parts. The PO said there was a limited slip in there, but I never removed the inspection cover to check.
I've got an engine hoist to move these suckers around.
The pictures below are of the 14 bolt.
Jeez...... Free.... does this stuff grow on trees in Cali ???:dunno:
never come across deals like this in Texas...:rolleyes::rolleyes:
If I had a place to put them, id grab them, but I don't and I already have a 14 bolt that needs to move as well. Bump for a smoking deal.
Are you still having trouble getting rid of these? Please let me know (PM or post) if you are and I will see about coming down to the Bay Area next weekend.
