74kay5
[FONT=Arial, Helvetica, sans-serif]73-91 K5 Blazer, Jimmy, Suburban Crossover steering parts for Dana 44 1/2 ton or 3/4 axle. Must be flat top knuckle to work. Knuckle needs to be machined for studs, conical washers and lock nuts. Parts were aquired from someone else and never used. Steering arm is a full 1" thick and tapered for GM washers and the drag link ends supplied. Draglink is made from thick DOM tubing and 1/4" plate. The drag link ends are the HD Spicer type. The draglink is angled to prevent it from hitting the engine crossmember wich happens with the straight type. Grade 8 hex bolts included. Parts were primered and painted gloss black and hammered silver. Jam nuts for drag link ends are included. $350 San Rafael CA
[/FONT]
[/FONT]
