dana 44 crossover ??
Jason4x4
Chandler, AZ
I am piecing together my crossover for my dana 44. I was going to go put the flat top on, and I also need to put the drivers side on too, cause the tie rods go down on the flat top. the old ones go up.
Here is my question. The linkage for the flattops has the hole for the stabilizer in a different location. If I use the linkage from the original that go up, the taper for the stabilizer will be backwards. Is there someone that makes a bolt on bracket, like the dual stabilizers, but for a single. If that makes sense.
