Dana 44 or 10 bolt wich is better?
I would us the dana44 because you will have the right gears in front. If you stay with the 10 bolt you will need new gears. I just picked up the same set up. And I will use the dana44 because the gears will match and if you ask me the dana44 is stronger than the 10 bolt. Just by looking at them you can tell the difference. If I was you I would get rid of the 10 bolt.
Just my opinion. Later LittleJimmy.....
