dana 44 outers
thebluemax
Hutto,TX
What is needed to swap a set of Dana 44 outers onto a ten bolt? 10 bolt is an 84 Chevy 28 spline,outers are of 78 k20. Outers come with spindles, calipers, caliper mount hub, and rotor. Is there anything else I need? Anything that I might want to replace while the axle is taken down?
From the knuckle out, all should be the same IIRC. Barring using the whole D44 (my first choice) I would do all the seals both on the outers and the pumpkin as well as carefully check the bearings. New ball joints for sure
I didn't want to regear the front to match the rear I have my eye on. Rear axles seem to be easier to find than fronts.
