Dana 44 spindles (77 and earlier)
bp71k5
3/4 ton status
Knoxville, TN 37922
These are good used spindles that have the smaller inner bearing. I think they were used on dana 44 axles before 1977. They are the same as all the rest, but use a smaller diameter inner bearing.
$40 shipped
Brian, which ones would fit for the D44 I got from you? I'm assuming the D44 I have is your OEM axle just with the swapped 8lug hubs right?
Hoby,
I converted that axle over to the larger bearing spindles. They are supposed to be better and the bearings are easier to find in the parts stores. These small bearing spindles were pulled from the axle you bought.
Maybe you need a set of both? :)
I had a few sets of these in the past and had really good luck selling them on ebay. A lot of Jeep guys like these because they can run there jeep rotors on ford axles or something like that.
Rick
Would be happy to take these of your hands if you still had them.
