Dana 44 with 8-lug hubs and 4:56
where abouts were you thinking? In the middle like near Easton, PA or the general area.
Easton or there aboots would work. I have to see what my money situation, might not be for few weeks.
the rust is kinda turning me away. how much do you think it would cost to redo the brakes and get it road worthy?
The axle has surface rust mainly. The center section still have fluid in it to keep the gears from flash rusting. I would have to drain it for shipping. As for the brakes I would replace the calipers, I left them on to be used as cores. The rotors have very few miles on them and SHOULD be able to be cut and reused without any problems. As far as I know getting rotors cut is usually pretty cheap, new calipers well that depends on were you by them and if you get them with pads or without, in this case with is the better choice. I would have to go over it again but it shouldn't need anything other then the brakes and fresh fluid to be road worthy.
If your really interested in this and would like to save some on shipping I'm going to be in the Williamsburg area of Virginia from the 14th to the 21st of this month. I would be able to meet up to exchange with in a reasonable distance from there.
well i still would buy it your just to far away $200 and i will take it so you got a buyer just not a way to get it to me!!!:D
I can ship it once I get home at the end of this week. That's the only other way of getting it to you. That doesn't require either of us doing a **** load of driving at least.
yeah i just cant do that crazy shipping charge. if for some crazy reason you ever come around ky send me a pm. nick
