Dana 44 yoke change
What vehicle, are you sure its a rear D44?
If so, just about every D44 uses shims to set pinion bearing preload. That being the case, you just need to remove the nut and yoke, replace it, use a new nut and torque to spec.
Im sure it is a Danna 44. It come out of a 95 Isuzu Rodeo. I swapped it in my S10 Blazer.
Now I just need to find 2 1310 44 yokes that use the u-bolts.
