I am going to install a Dana 60 front and a GM 14 bolt rear in my 87 K-5. It will have an 8" suspension lift and I will be running 37"s or larger. I am looking at many different axles on craigslist and varies sites. I want to know what is the best route when buying thee axles. Should I buy a cheap one and build it myself or is it cheaper in the long run to purchase one already built with lockers and all. To give you an example I can buy both the axles for $500 used stock or $3000 built
