Doesn't exactly answer your question, but wanted to mention the extra thick nuts.
I own a book called Engineering Reminiscences by Charles Porter.
I actually have two copies. One is an original signed by the author in 1908. The other is a copy.
Got the copy here:
https://www.amazon.com/Engineering-...929&sr=8-1&keywords=engineering+reminiscences
This guy died in his 90s, and lived through most of the industrial revolution. He met people like Professor Rankin, Mr Pratt and Mr. Whitney, and was involved with some of the greatest achievements ever.
Many of the things we take for granted, he was around when they were created.
For instance, he was visiting a small machine shop, and saw them drilling holes in steel with some kind of new tool. Up until then, everybody he knew drilled holes with boring bars.
These were some kind of twisted rod. They said that they heated flat bars, twisted them, then sharpened the ends. Called them "twist drills".
He also met the guy who started Western Union telegraph. Turned out he was the sheriff from his home town.
I don't have the book in front of me, but there was somebody of that time that was
The authority on all things machinery wise. When you needed to know how to do something, you read his writing on the subject, since he was the best there was.
Porter was in England I think, at a engineering show. They were huge back then, think the electronics show in Vegas now.
He was walking by a display, and there was a large bolt clamped in an apparatus that had been pulled completely in two. The head end was clamped in the base, and the drawbar that pulled it to failure was held to the bolt with a nut that was not any more than the thickness of the bolt its self.
Porter was shocked, and exclaimed " Old -------Lied!"
The expert had proclaimed that to harness the full strength of a bolt, the nut had to be a certain number of times thicker than the diameter of the bolt. Of course, he had no proof of that claim, it just sounded right to him, so he stated it as fact and everybody the whole world over accepted it.
These guys with their hydraulic pulling machine had proven him wrong since the nut was nowhere near as thick as he said it had to be, and the bolt had pulled in two rather than the nut or threads failing.
Since I read that, I have seen many old time boilers, and other machines that had ridiculously thick nuts. Now I know why. There are other reasons, but for anything built in the 1800s or for a while in the 1900s, it was because of that one guy and his idea of the way things should be.
