I've been on the lookout for an 8 lug diff for my '66 burb for a while now and came across a Dana 60 out of a '70 Chevy van. I was looking for a 14bolt ff but this seems like it would work out good. What do you guys think? Thanks.
The Van spacing is wider than your truck, can't remember exactly how much more but enough to where you can place the new perch on the right spot and not worry about the other one.I've been on the lookout for an 8 lug diff for my '66 burb for a while now and came across a Dana 60 out of a '70 Chevy van. I was looking for a 14bolt ff but this seems like it would work out good. What do you guys think? Thanks.
As far as strength I know they can take quite a bit, if you got the full float D60 it's pretty close in strength to a 14bff an lighter and slimmer.
As I said pretty close, better than a 14SF not as good as a 14FF.The Dana 60 FF is actually not as strong as the 14FF but stronger than a 14SF. It has a 9.5" ring gear compared to the 10.5" on the 14FF. The 14SF is also a 9.5" ring gear but the SF axleshafts become the weaker link.
$200 for a D60 rear that will need perches redone? maybe not your best choice, at that price a 14bff that is a bolt in would be better.Thanks for the replys. I talked to a local drivetrain guy today and he said he has a few 14bolt ffers in his yard and thinks more than one should have 4.11s to match my front diff. When I asked like 6 months ago he didn't have any. He said depending on condition, it sould be $200 or less which is what the guy wanted for the 60. I'll go back after new years and get one if it measure out okay.
The 14 bolt seems kinda overkill for my application, which is why I liked the idea of the smaller 60, but everyone seems to say the the 14 bolt ff is my best choice.![]()
That is the D60 that I have, it came out of a 71 2wd 3/4 ton chevy pickup.The 14FF would have to be out of a 1 ton to be a bolt in, but it will still need shock tabs relocated. The only true bolt in's will be from a 1960-72 GMC 3/4 ton 4x4 with a Dana 60 rear. The 4x4's have 40" spring perches (1960-66) and the 2wd's have 42.5" perches (1963-66 only). The 67-72 body style the Chevy's started offering leaf springs as an option in 2wd trucks as well as the D60.
