NY Dana 60/70 10 lug front hubs
b454rat
Binghamton NY
Prolly a needle in a hay stack, but looking for some Dana 60/70 Ford 10 lug front hubs. They would be off 91-02 3500HD 4x4 converted trucks. Some have them some don't.
why not just gm drw hubs 8 lug then 19.5 bread truck drw rims and done . . ya I know spare would be 2 of them 1 10 and 1 8 lug . prob find this stuff 10x faster .
I got few sets of gm drw hubs.
I can get multiple sets of 8 lug 19.5s, but wanted to keep the 10 lugs for simplicity. I'll prolly end up swapping the rear for a 14ff or a Dana 70. Dually hubs for a Ford are stupid easy to get....Not in a hurry, just bought a house and no garage yet...
I have 2 Monroe converted 3500HD's. They are really hacked together. If I was converting one to 4X4, I would use a 2005 or newer F450 or F550 front end and have a spacer made to adapt the 10 on 170mm unit bearing to a 10 on 7.25" pattern or just swap in the rear axle from the Ford.
About half of the converted 3500HD's just use the 8 lug hub and bread truck 19.5's. The hubs off of the 4X4 converted pre 99 Ford F-Super Duty usually use GM/Dodge Dana 60 spindles and modified GM type hubs. They can be used too, but The hub would need to be turned down from 5.46" to 5.25" and the lug studs would need to be changed from 9/16" to 5/8".
I might be looking for 19.5 rims for a buddys build . pm me on them please .
Well either way not gonna happen. I made some calls, and the tires I wanted to run are over $500 EACH, and the rims are $300 each. Over 4 grand in tires/wheels? No f'n way. Also, found a set of 10 lug hubs but they are $800. Each. So, ain't happening. Gonna sell the I-beam front and Dana 80 rear, run the 78 Ford HP 60 I already have and 14ff or D70, run some widened 16" dually wheels and some 315/75s.
I've been on the phone all morning, calling various places if they had or knew where there were some. Nothing. Nada. Zilch.
