DesertFox00
Newbie
Okay so I have a 1987 K5 that I'm working on, I want to do a 1 ton axle swap to handle big tires and torque. I found a Dana 60 housing for about $350 I wanna put all new Yukon shafts, Reid knuckles, yoke, rack pinion, arb air locker, and everything. Would I be better served buying the housing and starting from scratch or a used axle with everything and replacing it all? Around here used D60 are going for about $1000-1600.
The rear axle will be a 10.5" 14bff, 12 valve Cummins, NV4500, and NP205.
