dana 60 axle seals
protechk5
VA
Ok im changing my axle seals on my front d60, and im not sure if i got the old ones are out all the way. Is it like a 2 piece seal or something? This is hard to explain but where im trying to put the new seal on, theres some other piece that is on there, im not sure if that is the old seal or if thats what the seal presses into. Does anyone have any idea what im trying to say, if not ill get pictures tomorrow.
It is possible you pulled only the rubber portion out and left the metal case of the seal behind? Best to get pics though.
ok here r some
so do you see that gold piece, is that part of the old seal, or is that something else. cuz my new seals dont have that
On my Dana 60 it was part of the old seal. But I don't know if they made different seals for different years.
Mike
Easy Way
You have to bang them out into the diff housing. Get a 1.5"x 4ft piece of Black or galv. threaded plumbers pipe from Home d or lowes. Also get a coupler. Grind down the coupler until it fits in the tube. Slide it down bang the end with as hammer and they should pop right out. After your done the pipe works great as a breaker bar.
I think I have a pic.
Everything is easy if you have the right tools though!!
guide tube
I think its called the axle guide tube, I just ordered them with the seal.
where did you order them from? is that something that autozone or someone would have??
I use a broom handle to pop the old seals out. The new two piece seals rock, a lot easier...make sure you clean up the Dana 60 seal seat real good...
alright well my local parts store had them, ha like $50 a piece tho. anyways how do tell if the are seated right? the rubber piece can side on the guide part.
