Wondering what your suggestion would be for front axle shafts in a Dana 60 running 47" tires? Need to decide what inners and outers to run along with what u joints. Thanks
Ya stock shafts, soon to be aftermarket.Still stock shafts?
I'd love to go with the RCV's, I was looking at those the other night. The lifetime warranty covers them up to 47" tire.I already gave you my recommendation, but I've had good luck with the Yukon 4340 shafts.
If you have a wide open budget, then I'd go with RCV's: http://www.rcvperformance.com/product-details-axles.aspx?sku=CVJ60OS-GM1
^What he said. 47's on 1 ton's are doable, some dudes in TTC have done it, but if you notice just about all of them are running chromo 35 splines inner and outer with rcv joints (since the rcv's have the 6 "ball" design that spreads the load/force over a greater area instead of a normal joint that has 4 points to spread the load/force over, this is where they get their overall strength from). This plus upgraded knuckles (or at least braced stock knuckles yourself) will usually get you some long life out of your front end...depeding on how hard you are on your rig.
I still have concerns about my d60 with 44's. I have 35 spline inner and outer (non-chromo's) with drive flanges and stock knuckles. So far after every trail I have inspeacted my joints and knuckles and have been good so far after 6 months. I still have my steering in the stock location on the knuckles which I think will help their longevity, and I do not beat on my rig hard at all. If I start hopping, I let off the gas and back up for a new line. Plus, my bone stock tired TBI 350 can't turn them too fast anyways, haha. But mine is just a trail truck with no high HP speed stuff, so it suffices. If I brake shafts/knuckles that is when I will upgrade.
Oh, and on a side note, your rig is sick! I want to go wheeling with you one of these days.
Thanks for your input. I would buy the RCV's but I'm saving up to buy front and rear coil over kits from those awesome guys at ORD! I also want an ORD front bumper for my K5.Stephen and I both have Superior shafts, they're gone now.
The Yukons are probably the best bang for the buck, especially with your deal through Summit. Get a good u-joint too, Yukons are lifetime warranty if you use their shafts and joints together.
The RCV's are probably the best but obviously have the price point against them.
