Dana 60 Brake line?
blazd88
Lubbock, Tx
so my extended brake lines wont work on my dana 60. I did some research and found out that 77-78.5 calipers use larger 7/16ths banjo bolts. Can i drill out the block to fit the larger banjo bolt or does anyone have a part number for a extended brake line with the correct size?
I drilled mine out, the 60 i have is a didge unit so it has the bigger banjo bolt. I ran it that way for awile with no leaks but had to get longer lines anfter the 52" swap so put the correct lines on. Its just a hole in metal, make sure you have good washers on both sides and it should be fine.
yeah those are the lines i have on there now(actually superlifts version but for ifs trucks). thanx for the help here comes the drill.
Dodge and Chevy 60s are different in a couple ways, the banjo bolts are not the same for them, dodge used the 7/16th, also the calipers are different, dodge used a 1.25" thick rotor and the calipers wont open big enough to accept the 1.5" rotors chevy used, trust me i went back and forth to the parts store to know
