FlatBlackBurb
so having recently gone 1-ton in my '87 suburban, i noticed that the brake lines were't sealing correctly where the bolted up on the caliper. i'm using standard steel braided brake lines from skyjacker for an 8'' lift. i noticed that the brake lines i took off the 60 looked more like a box where the bolted onto the caliper. should i just take some gasket maker to it? or do i have the wrong brake lines here. any help is appreciated
