sweetk30 Back to play nice . Premium GMOTM Winner Joined Nov 1, 2004 Posts 43,016 Reaction score 25,463 Location in the back of your brain Mar 6, 2025 #1 Anyine seen any offerings for big brake upgrade on a DRW dana 60 gm front axle ? All the stuff i see is based on SRW stuff .
nvrenuf Holy crap, it's running! Premium GMOTM Winner Joined Jan 7, 2002 Posts 22,128 Reaction score 12,107 Location Mobile, Al. Mar 6, 2025 #2 Wouldn’t it still fit? The rotor is still located the same. You'd still need the larger diameter wheels.
Fastereddie Sorry if I offended you. Not. Staff member Moderator GMOTM Winner Joined Aug 6, 2016 Posts 10,433 Solutions 1 Reaction score 22,588 Location Henderson Nevada Mar 6, 2025 #3 nvrenuf said: Wouldn’t it still fit? The rotor is still located the same. You'd still need the larger diameter wheels. Click to expand... I wouldnt think so because the newer/larger rotor slips over the hub on those setups.
sweetk30 Back to play nice . Premium GMOTM Winner Joined Nov 1, 2004 Posts 43,016 Reaction score 25,463 Location in the back of your brain Mar 7, 2025 #4 Fastereddie said: I wouldnt think so because the newer/larger rotor slips over the hub on those setups. Click to expand... And with DRW the wheel mounting flange is in the way of letting you slip it over .
nvrenuf Holy crap, it's running! Premium GMOTM Winner Joined Jan 7, 2002 Posts 22,128 Reaction score 12,107 Location Mobile, Al. Mar 7, 2025 #5 I didn’t realize the big brake kits were slip on from the outside, I figured they were still. held on by the studs. What about an SRW hub with a late model bolt on dually adapter and sandwich the rotor?
sweetk30 Back to play nice . Premium GMOTM Winner Joined Nov 1, 2004 Posts 43,016 Reaction score 25,463 Location in the back of your brain Mar 7, 2025 #6 nvrenuf said: I didn’t realize the big brake kits were slip on from the outside, I figured they were still. held on by the studs. What about an SRW hub with a late model bolt on dually adapter and sandwich the rotor? Click to expand... Late model factory adaptors dont fit over srw hub body. And none in 10x7.25 bolt pattern .
