dana 60 brakes
rob75
Registered Member
santa cruz
can some one point me in the right direction i searched and found good info but not what i was hoping to find.
my gm Dana 60 front came with no brake calibers i need part #s and an exploited view of the brake assembly so i can find all the parts needed.
thanks for the help
Is there no good parts houses in your area? We have Six States here in Salt Lake City and they are real good at knowing what you need. Brian
I just took a look through my receipts and think i found a part number for you, try 16-4166 and 16-4167. These were bought from my CarQuest store.
Those are either the D60 calipers or the Caddy Eldo calipers.
my question is the caliber slides on the bracket and the bolt holds it in place?
there are no other parts? my Chilton manual is pretty vague on this.
That is correct. They are like most Fords and just use a spring tension clip and bolt to hold the clip in place.
I may still have some good used spring tension clips if you can't find any.
thanks for the help. i cant wait to button this thing up and get it in the truck.
I needed some new hardware with my 60 I beleive I asked for a hardware kit for the axle and got the slide the spring and the bolt
