handloader90
Building!
Negative, haven't done shims yet.By any chance, do you have shims installed?
Perhaps one on bottom only on ds, and one on top and bottom on the ps?
IL look at my k5 when I get home a look at where the stickers are I'm betting they should be on the same end .Negative, haven't done shims yet.
That's what I'm guessing.IL look at my k5 when I get home a look at where the stickers are I'm betting they should be on the same end .
It's military housing.Brave man in an HOA![]()
37x12.5x16.5 Goodyear MTR's mounted on stock GM 16.5 steel wheels, I believe they are 7" or so wide (not sure).What size wheels and tires?
Looks like overload leaves are pulled out. If that's the case, "W" shaped springs will happen soon... Been there and tried that. Specifically with a set of TCI 56" rear springs. The overloads tend to make them too stiff but they need to be there for longevity. And I'm not talking longevity as in they take years to die, I'm talking dead within a couple good trips.
