Dana 60 DRW hubs and rotors - Phoenix area, local pickup only
Bad Karma
Registered Member
Glendale,AZ
Converted my 60 to SRW hubs, don't need these taking up space. Rotors have surface rust, but they look like they're pretty good. Local pickup in Phoenix metro area only, don't want to ship these.
50 bucks for the pair.
77ChevyK10 said:
just a ? dose the DRW and SRW use the same axel shaft and spidle
to answer your question . all you need to do is pick srw or drw and install that hub/rotor unit on the axle. its all the same otherwise. vary basic but efective swap.
just asking so thanks
will u take $40 if so and they are in good shape then ill buy them
