I think I'll go with this. I made a final adjustment for Backlash and had to adjust pinion Preload. All is set for new bearings and races.
Took some time off the project to put up Halloween decorations and fix some house stuff. Plus, setting the gears was becoming frustrating. I was OVER thinking the whole thing. I failed to set pinion depth FIRST then adjust the carrier left/right afterwards. I was adjusting everything each time I changed something.
I finally heeded a recommendation and set the pinion depth and then adjusted the carrier backlash. Even then the patterns never looked like the photos of "perfect" or ideal patterns.
I guess I was optimistic the pattern would end up being be pretty ovals and look like all the drawings and picture posted for "ideal" patterns. Thinking now that as long as the pattern is centered up/down on the tooth and centered top/bottom + or - a 1/4 inch, I'll be good to go. I can kill myself trying to get the perfect pattern in the photos. It's like trying to find the milk jug with the never expiring date.
