Dana 60 front & 70hd rear
diablo1
colorado
Just picked up a dually 60 and can get the 70hd that goes with it. I beleive it around 74" wide. I would like to use my H2 wheels on this set up. How wide would this set up be with h2's mounted? Would the 70hd bolt right in or would i need to move the perches? What about rear brakes? can I still use the drums or would I have to change to discs? Anyone have pics of this set up? I would rather use the H2 instead of going H1's. Or would it be better to single out the 60? Any info would be help full. I have searched but all I have found is people using H1's and not much info specific to my questions.
Thanks for your help.
Brian
i think it would be too wide with the H2 wheels. people use this setup with H1s cause they have like 7 inches of backspacing. i have H2s on mine and i think it would look goofy with them like 6in wider on each side.
if your set on the H2 wheels i would suggest convert the front to single wheel and pick up a 14bff rear. and if you could get a rear end from a van (3in wider) i think that would be ideal. thats just my .02
