dana 60 grade 8 spring plate bolts...
muddybuddy
1 ton status
Northern, VA
hey there, i need to get some bolts for d60, what size do i need? is it just 5/8" the whole way? are studs basically only a dealer thing? i havent been able to locate any locally. im trying to get the axle on tomorrow.
thanks.
The bolt size is 5/8" x 11 tpi and you should be able to purchase the bolts from your local hardware store. Yes the bolts are the same size all the way down.
