Dana 60 High Steer arms w/ Knuckle tie in kit
4WHEELSUPPLY
Registered Member
VA
Here is a new arm I just finished. CNC Plasma burnt from 3/4" A36 Steel. Then CNC Machined on a FAdal Vertical macining center all here in house. Kit will include 2 arms, all neccesary springless conversion hardware, 2- 10.5" 5/8" B7 Allthread 2-pcs of 1" OD x 5/8" ID DOM tubing and 4 NyLock nuts. This will allow you to add another mounting location on your D60 Knuckle to add even more strength. Going to leave hole undrilled for 5/8 bolt just because all knucles will be different, so location will also be different. As always FREE SHIPPING. Kit will run ya $135. And you can add a stud/nut kit for $15
