dana 60 hubs
tourdog
Registered Member
madison me
well I have searched here and pirate with much luck i need to find the treads or manuls on converting dual hubs to single . I have seen them some were just need to find and do it .please point in right direction .now for second question i have read here or pirate a guy put a sm465 tras behind a 400 but can not find it agin then he put 2 465 trans togeather but can not find it I would like to read it more and try it .thanks
well for the hub conversion, undo the caliper and the spindle nuts. pull off the DRW hub and put on the SRW hub. tighten down the nuts and put the caliper back on. tada!
hubs
well I thought it was that easy but I thought one could unbolt the extention on it to but maybe not . now if I can find that other thread about transmissions
There is no extension to unbolt on the older style DRW D60. You are thinking of newer trucks with unitized hub bearings which usually just have a spacer bolted on.
