Dana 60 install
Hubnut
Gainesville, FL
Finished the 14bbff this morning and decided to tackle the 60. Went pretty easily. DIY4X sent one wrong ubolt, so I had to use an old one that only grabbed with about 1/2 a bolt length. Have to fix that. Also, the steering needs attention. I guess I'll order the high steer cross over Monday. Best vendor for that? The height came out pretty level I think. Hit my head at least 3 times in the same spot--nice lump there!:doah:
I'm in the process of doing the same swap. I ordered my crossover from ORD. It's actually on its way as we speak. I also got my extended brake lines from them. Not to mention Bilstein 5125's came from them too! Swap looks good, keep it up!
Oh, you won't be able to use your sway bar with the crossover. That's what I'm told anyway.
Sway bar is gone. It was safer to get rid of it after we got the axle installed and on tires.
