dana 60 knuckles and inner " C " pair's
sweetk30
Back to play nice .
in the back of your brain
I have a set of dana 60 knuckles from a chevy axle and also the inner " C " s from the same axle .
the knuckles are good n clean . studs clean threads . all holes good and clean with tap run in/out for clean up .
blasted knuckles and black painted . NO top knuckle studs or steering stop bolts . only spindle studs included.
the inner " C " s have the tubes still in them and need to be removed . the threads for king pin are good and take a king pin all the way no problems . these can be blasted before shipping if needed.
the axle tubes were cut off directly at the center section as the center section was junk . so if building a custom axle or other combo the tube length can be set by you or I can cut off the rest of the extra .
looking to get $175.00 shipped for the knuckles .
and also $150.00 inner "C"s . to determin the shipping on needs .
all parts are best offer .
