bp71k5
3/4 ton status
The drivers side hub keeps moving off of the "free" setting while driving. I've read there is some kind of set-screw solution I can do but does anyone else have this problem? These are the warn premium style.
35 spline outers? I've read about 35 spline outers rubbing in the inside of the dial causing it to turn. If this is the problem swapping the stock inner wheel bearing race for a D60 carrier bearing race will push the hub assy out approx 1/8" and fix the problem.
