So I put new king pins in the 86 k30 to get rid of the death wobble went great, when i pulled out the axles they needed new u joints so that is done. Now i have everything together up to putting the hub/rotor on. My question is is that I have got some metal shavings because the inner drive gear is rubbing on the hub body on the manual locking hub. So if i buy new lock outs will they come with this all new or where is a good place to get these parts? Also what would be causing these parts to rub together? I have the warn lockouts. thanks in advance
