dana 60 lower kingpin bearing cap
Here you go.
http://www.extremeaxlesales.com/index.asp?PageAction=VIEWPROD&ProdID=26
I have a set of billet steel CNC'd lower king pin caps. I had a friend make them but never got around to installing them as i fixed my problem, (which turned out not to be the caps). If interestred PM me.
I'm not so sure i would like the idea of having to tear the whole knuckle off to grease the lower bearing since the one on e-bay says there is no grease fitting and it's too hard of material to drill for one.
Good luck though.
