Dana 60 Noob Q:s...
sebban
sweden
I´ve checked on summit and I´ve tried search here..
Tie-rod ends, are the the same for 10bolt vs. dana 60??? (it looked like the same part number too me..)
Attachment to the springs, I know you use u-bolts on three places, but the fourth? Do you use a regular bolt? If so, what size and thread?
Thanx, Sebastian
do you have a d60 front or are you doing some searching?
I know my tierod ends were different size between my d44 and my d60... physically the d60 tierod was bigger... IT WAS HUGE :haha:
also yes drivers side (gm d60) has 2 ubolts as the passenger side has 1 ubolt and 2 studs that are in the axle. You use 2 nuts to bolt the leafpack down...
however some loose or break the stud and use grade 8 bolts. I have the studs...:bow:
I got the axle yesturday.. (and I have brand new parts for a complete 10bolt still in the boxes but I don't want to tear it down unless I have new parts waiting)
Ok, the studs in my axle were gone so I guess i'll just get some bolts.. :)
thanx!!
the tapered part of the tie-rod ends are the same, but the threaded portion on the d60 tierod ends is larger.
