Dana 60 off a f*rd in my Blazer???
chaka73
Southern California
Can I use a Dana 60 off a f*rd F250 pick up with 4:11s in my Blazer or is this a stupid question?
LOVE MY GREEN GIANT!!!
I belive the feerds use 5lug axels?? Don't they??
I would also think the spring perch location would be wrong??
I am going by memory so with that in mind I sure could be wrong!!
Rock ON!
72 K5
Led Zeppelin
ah, no... period (for the front). The pumpkin is on the wrong side of the truck. However if you're talking about the rear... I don't know.
NEVER been stuck... *yet*
<font color=blue>You can use a d60 rear but it requires a little more work than a 14 bolt will. you need to weld on new perches and shock mounts and get a new driveshaft. If you are good with a brakeline bender and flarer you could make hardlines to adapt the drums but disks would be easier. I found one from a f350 and i'm probably gonna put it in</font color=blue>
yeah cause I found that one off an F250 for $125, but I think that between this one and the 14 bolt I need to modify alot more with the Dana than with the 14, I'll think about it thanks anyway.
