dana 60 parts + 14BFF
YZEATER
TARENTUM, PA
set of dana 60 spicer original hubs. 1 hub worked fine, i worked, but when you went to lock it i the dial would keep spinning all the way around with no stop. it would unlock and stop. someone thought it would be a good idea to install a grease fitting in the caps/covers , look on the pic.
$80 shipped.
some dana 60 brake parts. good brake pads. calipers could be cores, i never used them to see if they work. have some rotors too.
cab & chassis 14BFF disk brake brackets. $55 shipped
weld on 14BFF disk brake bracket. JUST 1 . $25 shipped
