Dana 60 parts
Pick up a couple of spindle bearing kits - part # "SBK-3". these will have the needle bearing plus the seal and spacer you want plus a small seal also.
Fyi, replacement spacers are made of plastic. If you have bronze spacers and they are in decent shape, I'd reuse them.
Looking thru my bag of parts I don't believe the spacer was there? Don't suppose you have a pic?
I don't have any pics, the only 2 I have are in my axle.
The spacer is approx 2.5" outide dia with 1.5" hole and about 1/8" thick.
Think I found it, between the v-seal and that smaller rubber washer there was a plastic spacer. That kit you referenced before has the both of those seals and the spacer?
Yeah, the kit will have the bearing, V seal, bearing seal and spacer.
IIRC, it replaces the bearing and 3 o'clock position spacer. I have them but can't remember what it replaces. Highly recommend
